Using the Service Order Operational Dashboard
This portal is used to display the Service Order Operational Dashboard.
You can access the portal from the Main > Dashboards > Service Order Operational Dashboard. Once you've selected this menu option, you're immediately brought to the initial tab of the dashboard.
  • In-Flight Activities By Type: shows the distribution of in-flight Activities (in progress or in error) by Activity Type.
  • In-Flight Activity Trend: shows the number of activities that are in-flight on a given day.
  • In-Flight Activities with Issues: presents a bar chart that indicates the number of activities with issues.
  • In-Flight Activity Status Distribution: presents a pie chart that displays the distribution of statuses of in-flight activities.
  • Efficiency Trend for In-Flight Activities: presents a stacked bar chart that displays the distribution of in-flight activity processing efficiency relative to configurable tolerance.
  • Service Order To Do Summary: this zone uses horizontal bars to highlight the relative number of open To Dos for a set of To Do Types related to Service Order Management.
