Device Communication Base Package Business Objects
The Itron OpenWay Adapter base package includes the following communication business objects:
Business Object Name |
Description |
D8-AddMeterDefinitions |
Itron - Add Meter Definition (Commission) |
D8-DeregisterMeter |
Itron - Deregister Meter (Decommission) |
D8-DetectLoadSideVoltageByMtr |
Itron - Detect Load Side Voltage |
D8-DetLoadSideVoltageMtrRslt |
Itron - Detect Load Side Voltage Result |
D8-DisconnectMeter |
Itron - Disconnect Meter (Remote Disconnect) |
D8-DisconnectMeterResult |
Itron - Disconnect Meter Result |
D8-PingByEndpoints |
Itron - Ping By Endpoints (Device Status Check) |
D8-PingByEndpointsMDResponse |
Itron - Multi-Device Ping Response |
D8-PingByEndpointsMultiDevice |
Itron - Ping By Endpoints Multi-Device |
D8-PingByEndpointsResponse |
Itron - Ping By Endpoints Response |
D8-ReadDisconStateByMtr |
Itron - Read Disconnect State |
D8-ReadDisconStateMtrRslt |
Itron - Read Disconnect State Result |
D8-ReadInterval |
Itron - Contingency Read (Interval) |
D8-ReadResult |
Itron - Contingency Read Result |
D8-ReadScalar |
Itron - Contingency Read (Scalar) |
D8-ReconnectMeter |
Itron - Reconnect Meter (Remote Connect) |
D8-ReconnectMeterResult |
Itron - Reconnect Meter Result |
Itron OpenWay Event Data Mapping
The Itron OpenWay event file format maps as follows into the business object, D1-DeviceEventMappingLookup:
Itron OpenWay Flat File Field |
Device Event Seeder BO Element |
Comments |
Transaction ID (from Header record) |
External Source Identifier |
This is the file name. |
Device Identifier |
External Device Identifier |
Event Name |
External Event Name |
Event Creation Date/Time |
Event Date/Time |
Device Type |
External Device Type |
This element has no real bearing on the device type within MDM/SGG. Its valid values include (although the element itself is free-form): Meter Collector Router |
Service Location ID |
External Service Location ID |
Communication Module Serial Number |
External Communication Module Identifier |
Event Category ID |
External Event Category |
Event Severity |
External Event Severity |
Valid values include (although the element itself is free-form): Alert Information |
Status Value |
External Status Value |
This represents additional information that relates to the event itself. |
Status Date/Time |
External Status Date/Time |
The date & time at which the additional information referenced above had occurred. |
