Installation Options - Main
Select Admin > General > Installation Options - Framework to define system wide installation options.
Description of Page
The Environment ID is a unique universal identifier of this instance of the system. When the system is installed, the environment id is populated with a six digit random number. While it is highly unlikely that multiple installs of the system at a given implementation would have the same environment ID, it is the obligation of the implementers to ensure that the environment ID is unique across all installed product environments.
System Owner will be Customer Modification.
The Admin Menu Order controls how the various control tables are grouped on Admin.
  • If you choose Functional, each control table appears under a menu item that corresponds with its functional area. Note, the menu that is used when this option is chosen is the one identified with a menu type of Admin.
  • If you choose Alphabetical, each control table appears under a menu item that corresponds with its first letter, using a Roman alphabet. For example, the Language control table will appear under the L menu item entry.
Note: The Alphabetical option only supports the Roman alphabet. For languages that do not use the Roman alphabet, the recommendation is to configure the system for the Functional setting.
CAUTION: In order to improve response times, installation options are cached the first time they are used after a web server is started. If you change the Admin Menu Order and you don't want to wait for the cache to rebuild, you must clear the cached information so it will be immediately rebuilt using current information. Refer to Caching Overview for information on how to clear the system login cache (this is the cache in which installation options are stored).
The Language should be set to the primary language used by the installation. Note that if multiple languages are supported, each user may define their preferred language.
The Currency Code is the default currency code for transactions in the product.
If your product supports effective dated characteristics on any of its objects, define the date to be used as the Characteristic Default Date on objects without an implicit start date. The date you enter in this field will default when new characteristics are added to these objects (and the default date can be overridden by the user).
Active Owner displays the owner of newly added system data (system data is data like algorithm types, zones, To Do types, etc.). This will be Customer Modification unless you are working within a development region.
Country and Time Zone represent the default country and time zone that should be used throughout the application.
CAUTION: In most implementations, the time zone defined here matches the database time zone. However, if there is some reason that the database time zone does not match the installation time zone, an implementation may configure a setting in the properties file to automatically convert data from the database time zone to the time zone defined here when displaying dates. Note that when this property setting is defined, changes to the installation time zone will require the server and the thread pool workers to be restarted in order for the changes to take effect.
Turn on Seasonal Time Shift if your company requires seasonal time shift information to be defined. Note that this is currently only applicable to Oracle Customer Care and Billing > Interval Billing functionality.
