Caching Considerations
There are two important caching considerations when using CMA to migrate administrative data.
  • The "apply" batch processes update data. As described in Batch Cache, if any batch job is updating data marked as "cached for batch" it must be run in a special thread pool. Contact your system administrator and ask for the name of a thread pool that has turned off caching. This thread pool name must be entered in the batch controls used for CMA processing in the Thread Pool Name parameter.
  • After a successful migration, the target region now has new administrative data which needs to be part of various caches. It is recommended to flush the server cache (which will trigger a 'global' flush of the cache). If the thread pool workers in the target region are configured to refresh their caches when a global flush is requested, then this is the only step required. If not, then the F1-FLUSH batch job should also be submitted to refresh the caches used in batch processing.
Fastpath: Refer to Caching Overview for more information.
Fastpath: Refer to Running Batch Jobs for more information about running CMA batch jobs.
