Load Data Batch Run Parameters
The data upload batch is processing single target object – Table or Maintenance Object. The data extract may be supplied in one or multiple files, created and named according to the Input File instructions for a Staging Table and Maintenance Object .
The process is multi-threaded and optimized for the parallel load.
Using the batch parameters you can control:
  • Level of logging
  • Data extract retention
  • Resume the interrupted load
  • Maximum number of load errors
