Using Rate Check with Oracle Utilities Rate Cloud Service
In addition to rate configuration functionality, Oracle Utilities Rate Cloud Service includes access to the Rate Check feature, which allows users to test their rates.
When using Rate Check, service quantities and characteristic types/values must be provided by the user and entered via the user interface. Oracle Utilities Rate Cloud Service does not support the use of the Rate Check feature based on service agreements, bill segments, or service points.
Refer to the Rate Check section in the Rates chapter of the Business User Guide for more information about using the Rate Check feature.
