Rate
In order to generate separate calculation lines for the revenue and tax breakdown of the prepaid amount, you need to set up a prepaid rate with components that calculate revenue amount and tax amount given just a total amount.
Create a rate schedule with the following components:
- Tax Calculation Rule- Calculation Rule Type = Calculation Algorithm
- Value Type = Percentage
- Value Source = Bill Factor
- Bill Factor = your tax bill factor
- Calculation Algorithm = the one created for algorithm type C1-PCTGVNTOT. Refer to Calculation Rule - Calculation Algorithm for information.
- Distribution Code = your distribution code for tax liability
- Revenue Calculation Rule 				- Calculation Rule Type = Calculation Algorithm
- Derive SQ = checked
- Value Type = Unit Charge
- Bill Factor = your rate/kWh bill factor
- UOM/TOD/SQI to use for the resulting calculated usage, for example kWh
- RC Cross Reference = indicate the sequence for the tax calculation rule (above)
- Calculation Algorithm = the one created for algorithm type C1-BACKINREV. Refer to Calculation Rule - Calculation Algorithm for information.
- Distribution Code = your distribution code for revenue
