Customer and Premise Data Extracts: Maintenance Object Audit Algorithms
Service Agreement
Account
Person
Service Point (MDM Service Point)
Install Event
Device
Service Agreement
Install Event
Account Change Data Capture (Customer Data Extract) (C1-ACCECDCCU)
Person Change Data Capture (Customer Data Extract) (C1-PERECDCCU)
Account Mailing Address Change Data Capture (C1ACCMACDC)
Device Change Data Capture (SP/Meter-Based) (D1-SPDV-CDCP)
Install Event Change Data Capture (SP/Meter-Based) (D1-SPIE-CDCP)
Device Change Data Capture (SP/Meter-Based) (D1-SPDC-CDCP)
An Account Change Data Capture (SA-Based) – Include Reactivated SAs algorithm type (C1-ACCCDCSAR) is provided in the base package. This algorithm type can be used to create an audit algorithm on the Account maintenance object to determine if a service agreement sync request record is to be created for each of the account’s non-closed, non-canceled service agreement(s). A change in a related account’s details will instantiate a Service Agreement Extract Sync Request (of the type defined for the SA Sync Request BO algorithm parameter) if one does not already exist in the initial state for the service agreement. The base package also contains an algorithm (C1-ACCECDCSA) that is based on this algorithm type.
A Person Change Data Capture (SA-Based) – Include Reactivated SAs algorithm type (C1-ACCCDCSAR) is provided in the base package. This algorithm type can be used to create an audit algorithm on the Person maintenance object to determine if a service agreement sync request record is to be created for each of the person’s non-closed, non-canceled service agreement(s). A change in the main person details linked to the service agreement’s account will instantiate a Service Agreement Extract Sync Request (of the type defined for the SA Sync Request BO algorithm parameter) if one does not already exist in the initial state for the service agreement. The base package also contains an algorithm (C1-PERECDCSA) that is based on this algorithm type.
