Defining Calculation Rule Eligibility Criteria
Use this procedure to define eligibility criteria for a calculation rule.
Prerequisites: You must create a calculation rule before you can define eligibility criteria.
- Click the Add link in the Eligibility Criteria List zone title bar.
- Enter a Sequence number, Description, and Detailed Description for the criteria.
- Complete the Criteria Comparison section as follows:
- Criteria Field: the means used to retrieve the value of the criteria field (algorithm, bill factor, calculation line, characteristic, contract quantity, service quantity, or historic service quantity)
- Comparison Operator: the operator used in the comparison
- Value: a user-specified value to which the retrieved value is compared (using the comparison operator)
- Complete the Comparison Results section as follows:    - If True: the action to take if the comparison is true
- If False: the action to take if the comparison is false
- If Insufficient Data: the action to take if there is insufficient data to perform the comparison
- Click Save.
See The Big Picture of Calculation Rule Eligibility Rules for more information.
