Creating Object Storage Locations
When using Smart Grid Gateway adapters with cloud services, you need to create one or more buckets in Oracle Object Storage where payload files will be sent for processing. Refer to the Oracle Utilities Cloud Services Object Storage Setup Guide and the Oracle Cloud Infrastructure documentation for more information about creating buckets in Oracle Object Storage.
After creating the buckets in Oracle Object Storage, make a note of the following, as this information is needed in later configuration steps:
- Namespace
- User Oracle Cloud ID (User OCID)
- Tenancy Oracle Cloud ID (Tenancy OCID)
- Compartment Oracle Cloud ID (Compartment OCID)
Suggested Buckets for Payload Processing
This section outlined suggested sets of Object Storage buckets for each of the Smart Grid Gateway adapters.
General Guidelines
As a general rule, each adapter should have separate buckets for each of the following:
- Usage payloads
- Usage archive
- Usage errors
- Device Event payloads
- Device Event archive
- Device Event errors
If an adapter uses payloads in more than one format (such as in CSV and XML formats), you should also consider creating separate buckets for each file format type.
Adapter Development Kit
The table below lists suggested Object Storage buckets for the Adapter Development Kit:
| Bucket Name | Storage Tier | Smart Grid Gateway Description |
| adk-csv | Standard | SGG ADK Adapter - CSV input |
| adk-csv-arch | Archive | SGG ADK Adapter - CSV archive |
| adk-csv-error | Standard | SGG ADK Adapter - CSV errors |
| adk-seeder | Standard | SGG ADK Adapter - IMD Seeder input |
| adk-seeder-arch | Archive | SGG ADK Adapter - IMD Seeder archive |
| adk-seeder-error | Standard | SGG ADK Adapter - IMD Seeder errors |
| adk-xml | Standard | SGG ADK Adapter - XML input |
| adk-xml-arch | Archive | SGG ADK Adapter - XML archive |
| adk-xml-error | Standard | SGG ADK Adapter - XML errors |
Adapter for Itron OpenWay
The table below lists suggested Object Storage buckets for the Adapter for Itron OpenWay:
| itronexception | Standard | SGG Itron OW Adapter - event input |
| itronexception-arch | Archive | SGG Itron OW Adapter - event archive |
| itronexception-error | Standard | SGG Itron OW Adapter - event errors |
| itronxml | Standard | SGG Itron OW Adapter - XML input |
| itronxml-arch | Archive | SGG Itron OW Adapter - XML archive |
| itronxml-error | Standard | SGG Itron OW Adapter - XML errors |
MV90 Adapter for Itron
The table below lists suggested Object Storage buckets for the MV90 Adapter for Itron
| mv90-usage | Standard | SGG MV90 Adapter - usage input |
| mv90-usage-arch | Archive | SGG MV90 Adapter - usage archive |
| mv90-usage-error | Standard | SGG MV90 Adapter - usage errors |
Adapter for Landis+Gyr
The table below lists suggested Object Storage buckets for the Adapter for Landis+Gyr:
| lg-cim-event | Standard | SGG Landis+Gyr Adapter - CIM input |
| lg-cim-event-arch | Archive | SGG Landis+Gyr Adapter - CIM archive |
| lg-cim-event-error | Standard | SGG Landis+Gyr Adapter - CIM errors |
| lg-event | Standard | SGG Landis+Gyr Adapter - event input |
| lg-event-arch | Archive | SGG Landis+Gyr Adapter - events archive |
| lg-event-error | Standard | SGG Landis+Gyr Adapter - event errors |
| lg-usage | Standard | SGG Landis+Gyr Adapter - usage input |
| lg-usage-arch | Archive | SGG Landis+Gyr Adapter - usage archive |
| lg-usage-error | Standard | SGG Landis+Gyr Adapter - usage errors |
Adapter for Sensus
The table below lists suggested Object Storage buckets for the Adapter for Sensus:
| sensus-event | Standard | SGG Sensus Adapter - event input |
| sensus-event-arch | Archive | SGG Sensus Adapter - events archive |
| sensus-event-error | Standard | SGG Sensus Adapter - event errors |
| sensus-usage | Standard | SGG Sensus Adapter - usage input |
| sensus-usage-arch | Archive | SGG Sensus Adapter - usage archive |
| sensus-usage-error | Standard | SGG Sensus Adapter - usage errors |
Adapter for Silver Spring Networks
The table below lists suggested Object Storage buckets for the Adapter for Silver Spring Networks:
| ssn-csv | Standard | SGG SSN Adapter - CSV input |
| ssn-csv-arch | Archive | SGG SSN Adapter - CSV archive |
| ssn-csv-error | Standard | SGG SSN Adapter - CSV errors |
| ssn-ssnxml | Standard | SGG SSN Adapter - XML input |
| ssn-ssnxml-arch | Archive | SGG SSN Adapter - XML archive |
| ssn-ssnxml-error | Standard | SGG SSN Adapter - XML errors |
