Understanding Time of Use Map Templates
Every TOU map references a TOU map template that defines the rules for generating TOU data from that TOU map. Specifically, TOU map templates define:
  • The TOU group (defines the valid TOU periods for the template) used for the TOU map
  • The default TOU period used for periods not explicitly defined. (This means you don't have to specify dates and times for all periods. For example, if your default TOU period is "Off Peak" you only need to define dates and days and times for On Peak or other TOU periods.)
  • The specific date ranges, days of the week, and time periods designated for each TOU period.
The system periodically generates TOU map data for TOU maps by interpreting the rules defined template.
Attributes used to define TOU map templates include the following:
  • TOU Group: the TOU group used by the map template Default TOU: the default TOU for the map template (from the TOU Group). This is the TOU used when creating TOU map data for dates not accounted for in the TOU Schedules section.
  • Work Calendar: the work calendar used to identify holidays. On each holiday the Holiday TOU will be used. For additional information see Defining Work Calendar in the Oracle Utilities Application Framework Administrative User Guide.
  • Holiday TOU: the TOU used for holidays (from the TOU Group)
  • Holiday Template: the TOU map template used for holidays (if applicable)
  • Interval Size: the size of the intervals for TOU map data created from the map template, represented as hours:minutes:seconds (HH:MI:SS).
  • TOU Schedules: date ranges (including month, day, and time ranges) and which TOU periods apply to each
TOU Map Template Interval Size
TOU map templates can also specify an interval size (in seconds-per-interval, or SPI). This value specifies the duration of the individual TOU map data records, and also controls the values allowed in the Start and End Times. For example, if a TOU map template sets the interval size at 15 minutes, Start and End times must be in units of the interval size (10:00, 10:15, 10:30, etc.).
A TOU map template can be used to generate TOU map data for TOU maps whose SPI is divisible by the template's SPI. For example, a 60 minute template can be used to generate TOU data for TOU maps with SPIs of 60 minutes, 15 minutes, 5 minutes, etc. This means separate map templates are not needed for every SPI.
Holidays
Many utilities categorize consumption on holidays differently than on the day of week on which the holiday falls. For example, holiday consumption might be categorized as Off-Peak regardless of the day it falls on. TOU map templates can define rules for different TOU periods for holidays in two ways. Both options require that the template references a Work Calendar that identifies each of the holidays throughout the year. In addition they require either:
  • A Holiday TOU that will be used for each holiday for the duration of that holiday (e.g. Off Peak)
  • A Holiday TOU Map Template that defines the TOUs that should be used for holidays that fall during different seasons within the year (e.g. Off Peak Summer, Off Peak Winter)
Important Time of Use Template System Events
The time of use template supports the following business object algorithm system events:
  • Derive TOU: receives a date time and determines the TOU code for that date time based on the configuration of the time of use template schedule. See the Derive Time Of Use For Date Time (D2-DERTOU-DT) algorithm type as an example.
