Maintaining Facilities
This portal is used to display and maintain a Facility.
You can access the portal from Menu > Device Installation > Facility. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Facility: defines the basic attributes of the facility
  • Network Locations Related to Facility: displays a list of network locations associated with the current facility in reverse chronological order.
  • Service Points Related to Facility: displays a list of Service Points related to the current facility, in reverse chronological order.
