Turn Off A Function Module
The base package is provided with a Module Configuration Feature Configuration that allows your organization to turn off base package function modules.
To turn off any of the base package function modules add a Turned Off option to this feature configuration referencing that module. Refer to the MODULE_FLG lookup field for the complete list of the application's function modules.
Any module not referenced on this feature configuration is considered turned on, i.e. accessible. To turn on a module, simply remove its corresponding Turned Off option from this feature configuration.
You may view your module configuration setup on the installation options page.
Only one. The system expects only one Module Configuration feature configuration
to be defined.
