Maintenance Object - Options
Use this page to maintain a maintenance object's options. Open this page using and then navigate to the Options tab.
Description of Page
The options grid allows you to configure the maintenance object to support extensible options.
Select the Option Type drop-down to define its Value. Detailed Description may display additional information on the option type.
Set the Sequence to 1 unless the option can have more than one value.
Owner indicates if this is owned by the base package or by your implementation (Customer Modification).
You can add new option types. Your implementation may
want to add additional maintenance option types. For example, your
implementation may have plug-in driven logic that would benefit from
a new type of option. To do that, add your new values to the customizable
lookup field MAINT_OBJ_OPT_FLG.
