To Do Entries Created Manually
You must set up manual To Do entry types if you want your users to be able to create To Do entries online. Users may create a manual To Do entry as a reminder to themselves to complete a task. Online To Do entries may also be used like electronic help tickets in the system. For example, if a user is having a problem starting service, the user can create a To Do that describes the problem. The To Do can be assigned to a help resolution group that could either resolve the problem or send the To Do back to the initiating user with information describing how to resolve the problem.
If you want to take advantage of manual To Do entries, create a To Do type and specify the following information.
On the Main tab:
  • Set the To Do Type Usage flag to Manual.
  • Set the Navigation Option to toDoEntryMaint (To Do entry maintenance).
  • Set the Message Category and Message Number to the message you want to be used for To Do entries of this type. The system will populate the message parameter with the Subject. To show only the subject in the To Do’s message, use a message with “%1” as its text.
On the Roles tab:
  • Specify the To Do roles that may be assigned to To Do entries of this type.
  • Indicate the To Do role that should be defaulted when you create To Do entries of this type.
On the Sort Keys tab:
When a user adds a manual To Do entry, the system creates an entry with three sort key values. (Sort keys may be used on the To Do list page to sort the entries in a different order.) The To Do type should be set up to reference the sort keys as follows:
Sequence Description
1 Created by user ID
2 Created by user name
3 Subject
We recommend that the keys have an Ascending sort order and that the Subject is made the default sort key.
Note: It is possible to define additional sort keys and use a To Do Post Processing algorithm to populate the values. In this case, the base sort keys defined above should still be defined.
On the Drill Keys tab:
When a user adds a manual To Do entry, it is created with a drill key value equal to the To Do entry's ID. When the user clicks the Go To button next to the message in the To Do list, the system uses the drill down application service (defined on the main tab) and the drill key to display the associated To Do entry.
The To Do type must be set up with a drill key that reference the To Do entry table and the To Do entry ID:
Sequence Table Field
1 CI_​TD_​ENTRY TD_​ENTRY_​ID
