This page is used to define a user's favorite transactions and
URLs. Each such link appears as an entry in the Favorite Links Zone in the Dashboard area.
A hot key can be used to execute a favorite link.  Rather
than clicking a button in the favorite links zone, you can invoke
your first nine favorite links by pressing Ctrl + a number (where the number corresponds with the relative position
of the transaction in your list of favorites). Note that the numeric
keypad on your keyboard cannot be used to implement this function.
Open the User page and then navigate to the Favorite
Links tab to modify a user’s favorite links.
Description of Page
You may not be able to change your favorite links.  If
a Note appears beneath your  User
ID, your user id has been setup to reference a specific Favorites Profile User as defined on the Main tab. If a system administrator has setup your user ID in this way,
your preferences may not be changed. System administrators may apply
this feature in order to enforce a common look-and-feel throughout
the user community.
Each row references a Navigation Option. The navigation options supplied
with the base package correspond with the system's menu items. This
means you can setup a favorite link to open any transaction in the
system (in either add or update mode).
Favorite links can point to other places. The navigation
options supplied with the base package always open a transaction's Main tab. If you find yourself continually accessing
a different tab page, you can have your implementation team create
a new navigation option that references the desired tab page. Once
this navigation option is set up, you can reference it as one of your
favorite links. In addition, it's also possible for your implementation
team to setup navigation options that open a URL outside of the system.
For example, your implementation team could setup a navigation option
to a credit rating company's website. Once this navigation option
is set up, you can reference it as one of your favorite links.
Use a Sequence to control the order in which
the navigation option appears in the Favorite Links Zone.
Security Access indicates if you have been
given security rights to the respective transaction. Refer to The Big Picture Of Application Security for
more information.
Favorite Links vs. Bookmarks. Favorite links are configured
through the user page and define pages that a user can navigate to.
They do not define context (although some pages may use information
currently in global context when navigating). Some users may not be
allowed to configure their own favorite links and would see the favorite
links associated with a profile user. Bookmarks are created using
a bookmark button available on each page. The bookmark saves navigation
information, context information and also captures some information
about the state of a page. Bookmarks are not governed by any user
profile configuration.
