Conversion Batch Controls
The following batch controls are delivered with base product:
| Batch Control | Description |
| K1-CNVLD | Conversion - Load Data using SQL Loader. This process facilitates the legacy data extract upload using SQL Loader. The input data files are expected to be uploaded to a file storage location. See Input and Output File Location for more information about file storage locations. One run uploads the data into a single target Table or Maintenance Object. The process is multi-threaded. This process is discussed in more details in the Data Load Batch chapter |
| K1-CNVDS | Conversion - Disable Conversion This process resets the environment indicators and prevents further conversion activities. Once conversion is disabled, the following actions are blocked:
 Note: The process should be executed only once and only after
all of the conversion activities are completed and the application
is ready for the real production use. |
| K1-CNVEN | Conversion - Enable Conversion This process resets the environment indicators and enables it for conversion activities. It should be executed at the start of the Conversion project. |
| K1-DRPIN | Conversion - Disable Indexes on Production Tables This process can be used in two modes:
| K1-SDSIN | Conversion - Disable Indexes on Staging Tables This process can be used in two modes:
| K1-RIUSP | Conversion - Rebuild Indexes and Update Statistics in Production This process can be used in two modes:
 It is recommended to rebuild the indexes and update statistics right after the data upload. |
| K1-RIUSS | Conversion - Rebuild Indexes and Update Statistics in Staging This process can be used in two modes:
| K1-CLNTB | Conversion - Truncate Tables in Production This process can be used in two modes:
| K1-SCLTB | Conversion - Truncate Tables in Staging This process can be used in two modes:
| K1-CLNRT | Conversion — Truncate XML Resolution Tables This process
is allowed to run only in the Staging schema and may be used in two
modes:
| K1-CLNKY | Conversion - Truncate Key Reference Tables This process is allowed to run only in the Staging schema and may be used in two modes:
