Defining Configuration Reports
You use the Configuration Report portal to display and maintain configuration reports.
You can access the portal by selecting Admin, then Configuration Report, then Configuration Report. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Configuration Report: This zone provides information about the selected configuration report.
