Deposit Class - Refund Criteria
On Deposit Class - Main you must define the Refund Criteria Algorithm used by the system when it determines if it should automatically refund a deposit to a customer. Refer to Deposit Review for a description of the background process that reviews deposits for refunds.
If you haven't done so already, you must set up this algorithm in the system. To do this:
  • Create a new algorithm (refer to Setting Up Algorithms ).
  • On this algorithm, reference an Algorithm Type that determines if a customer qualifies for a deposit refund.
