Adding Rebate Definitions
Use the following procedure to add a rebate definition:
- Click Add in the title bar of the Rebate Definition zone.
 - Enter a Description of the rebate definition.
 - Select the Product for the rebate definition from the dropdown list.
 - Select the Service Type for the rebate definition from the dropdown list.
 - Enter the Rebate Per Unit Amount for the rebate definition.
 - Enter the Rebate Unit of Measure for the rebate definition.
 - Select the Expense Adjustment Type for the rebate definition from the dropdown list.
 - Enter the Presumed Energy Savings for the rebate definition.
 - Select the Presumed Energy Savings Unit of Measure for the rebate definition from the dropdown list.
 - Enter the Manufacturer and Model for each item eligible to be submitted as a rebate claim line.
 - To upload manufacturer/model information from a comma-separated-values
file, click  CSV File to Upload.
- Click Browse on the File Upload dialog, and browse to the file to be uploaded.
 - Click Upload.
 - Click Save. To return to the Rebate Definition zone without adding the rebate definition, click Cancel.
