Conservation Program Maintenance Object
A conservation program is an admin maintenance object (MO) used to support the definition of a conservation program. It holds rules that control how the claims for a conservation program are managed. If your organization wishes to use this MO, you can either use the business object (BO) supplied in the base product or configure your own BO.
This MO provides the following functionality:
- A business object option Display Statistics Service Script is provided for business objects of this type. The script plugged into this option retrieves information displayed on the Conservation Program Statistics Zone.
 - A business object option Display Statistics UI Map is provided for business objects of this type. This is the map used on the Conservation Program Statistics Zone to display statistics.
 - A separate maintenance object is provided to capture rebate definitions for a conservation program
 - Logs are not provided.
 - The standard characteristics collection is provided.
Fastpath:
For more information, about this MO and to review the business objects defined for this MO, navigate to and view the MO C1-CPROG.
