Bill - Characteristics
The Characteristics page is a grid containing one row for each characteristic linked to the bill. Bill characteristics are purely informational.
You can only choose characteristic types defined as permissible on a bill record. Refer to Setting Up Characteristic Types and Their Values for more information.
Open and navigate to the Characteristics page to view this information.
Description of Page
The following fields display on the grid:
- Characteristic Type must be a type of characteristic defined as permissible on a bill record.
- Sequence Controls the order in which characteristics of the same type are displayed.
- Characteristic Value indicates the value of the characteristic if the characteristic type is pre-defined or foreign key reference.
