Billable Charge Line Characteristic Upload Staging Layout
If you want to upload characteristics on your billable charge lines, you must create a billable charge line characteristic upload record for each characteristic on each line. The name of this table is CI_​B_​LN_​UP_​CHAR. The following table describes each column on this table.
Column Name
Length
Req'd
Data Type
Comments
BCHG_​UP_​ID
30
Y
Char
This is the foreign key to the billable charge upload staging record.
LINE_​SEQ
3
Y
N
This is the foreign key to the billable charge line upload staging record
CHAR_​TYPE_​CD
8
Y
Char
This is the unique identifier of the billable charge line characteristics. This value must be unique within the billable charge line characteristics.
ADHOC_​CHAR_​VAL
30
N
Varchar2
An ad hoc characteristic value must be supplied if the ad hoc switch on characteristic type is Y. Otherwise, it is not allowed.
CHAR_​VAL
16
N
Char
A characteristic value must be supplied if the ad hoc switch on characteristic type is N. Otherwise, it is not allowed.
CHAR_​VAL_​FK1
50
N
Varchar2
A characteristic value foreign key must be supplied if the ad hoc switch on characteristic type is Y. Otherwise, it is not allowed.
CHAR_​VAL_​FK2
50
N
Varchar2
CHAR_​VAL_​FK3
50
N
Varchar2
CHAR_​VAL_​FK4
50
N
Varchar2
CHAR_​VAL_​FK5
50
N
Varchar2
