Correction Notes Are Only Possible if the Installation Option Is Turned On
The Correction Note button on the bill segment and bill pages will only be available if you have selected the Correction Note Bill Correction option on the Installation record.
Fastpath:
If your implementation uses Correction Notes, it is recommended to also use the Freeze At Bill Completion installation option. For more information, see Installation Options - Billing.
