Eligibility Rules For Package 3
Package 3 (the single-family / gas heat package) in our example campaign has the following eligibility rules:
  • Customer class = Residential
  • Division = California
  • Birth date does not equate to that of a senior citizen
  • Lives in a single-family home
  • House is heated with gas
These rules require only one eligibility group on the package. It would looks as follows:
Group
No.
Group Description
If Group is TRUE
If Group is FALSE
1
Residential, Calif, Non Senior, Single Family, Gas Heat
Eligible
Ineligible
The following criteria will be required for this group:
Group 1: Residential, Calif, Non Senior, Single Family, Gas Heat
Seq
Field to Compare
Comparison Method
If TRUE
If FALSE
If Insufficient Data
10
Algorithm: retrieve order's customer class
= R
Check next condition
Group is false
Group is false
20
Algorithm: retrieve order's division
= CA
Group is false
Group is false
30
Misc Field On Order: Date of Birth
Algorithm: True if senior
Group is false
Group is false
40
Misc Field On Order: Type of Residence
= S (single family home)
Group is false
Group is false
50
Misc Field On Order: Type of Heat
= G (gas)
Group is true
Group is false
Group is false
