Configuring Exception Types
This portal is used to display and maintain an Exception Type.
You can access the portal by selecting Admin, then VEE, then Exception Type.
  • Exception Type List: displays all of the Exception Types so you can choose the one you want to display in more detail
  • Exception Type: shows the specific configuration for the selected Exception Type
There are two different options to use when creating an Exception Type:
Name
Details
Business Object
VEE Exception
This will create a "normal" VEE Exception that is attached to an IMD for tracking of conditions triggered in the VEE process.
D1-VEEException
VEE Exception - Monitor Service Point
In addition to tracking the failure in the VEE process, this VEE Exception generates a Service Issue Monitor. This allows for cumulative tracking of VEE Exceptions that can be configured to result in a Service Investigative Order (field work) for the Service Point.
D2-VEEExceptionServiceMonitor
