Configuring Measurement Reprocessing
This section describes the process for configuring Measurement Reprocessing.
Refer to the About Measurement Reprocessing section of the Oracle Utilities Meter Solution Business User Guide for more functional information.
Activity Type Configuration
Configuration for Measurement Reprocessing is performed by adding or changing an Activity Type. You can access the portal by selecting Admin, Communication, Activity Type.
Once the Activity Type search screen returns, locate the following records:
- Measurement Reprocess Activity - Interval: this Activity Type handles measurement reprocessing for interval Measuring Components.
- Measurement Reprocess Activity - Scalar: this Activity Type handles measurement reprocessing for scalar Measuring Components.
Use the Add button beside the record to configure for the first time. If a record has already been added, then click the Edit button instead. Use the embedded help to guide you through the meaning of each configuration field. By adding these Activity Types you are activating the process within Oracle Utilities Meter Data Management that will monitor changes to either the Measuring Component multiplier (the Register Multiplier for register measuring components or Channel Multiplier for interval and auto-read register measuring components) or the Install Event’s Installation Constant or Installation Date/Time. If any of these attributes change for a device, then a new Activity will be created that attempts to reprocess the measurements for the affected period.
Algorithm Configuration
The Detect Installation Constant Change for Install Event (D1-DETIECHG) algorithm detects changes to install events, including changes to the Installation Constant as well as changes to the Installation Date/Time. When the algorithm detects a change to either, it initiates measurement reprocessing.
The "Ignore Install Event Date Changes" parameter can disable automatic initiation of measurement reprocessing in the event of changes to the Installation Date/Time.
Related Batch Controls
There are a few batches involved with Measurement Reprocessing:
- Measurement Reprocessing Monitor (D1-MRAC): this processes any new Measurement Reprocessing activities that are created.
- Measurement Reprocessing - Retry Monitor (D1-MRER): this process retries any Measurement Reprocessing activities that fail to the Issue Detected state.
