Configuring the Service Order Management Dashboards
This section describes the process for configuring the Service Order Operational Dashboard and the Service Order Trends Dashboard.
Refer to the Using the Service Order Operational Dashboard and Using the Service Order Trends Dashboard sections of the Business User Guide for more information on this functionality.
Configuring the Service Order Operational Dashboard and Service Order Trends Dashboard includes the following:
Configure Activity Type
Configure the following payload statistics activity type:
Activity Statistics Aggregator Creator
Use the following procedure to create this activity type:
Select Admin, then Communication, then Activity Type. The Activity Type portal and Activity Type List zone open.
Click the Add/Edit icon for the "Activity Statistics Aggregator Creator" activity type in the Activity Type List zone.
Specify the following:
Create Aggregators for Field Activity Statistics: Yes
Create Aggregators for Command Activity Statistics: Yes
Activity-Requesting Service Providers: The external system(s) that sends service requests
Exception Handling: To Do Type, To Do Role, and other values as appropriate for your implementation.
Click Save.
See Configuring Activity Types for more information.
Configure Measuring Component Types
Configure the following measuring component types for each service type in your implementation:
Activity Processing Accumulation Aggregator
Activity Aging Snapshot Aggregator
Activity Processing Snapshot Aggregator
Activity Processing Derived Snapshot Aggregator
The tables below provide details for these measuring component types based on the "Electric" service type from the demonstration database.
Sub-Aggregator Measuring Component Types:
Field |
Activity Processing Snapshot Aggregator |
Activity Processing Derived Snapshot Aggregator |
Measuring Component Type |
ACT_PROC_SNAP_AGG |
ACT_PROC_DER_SNAP_AGG |
Description |
Measuring Component Type Business Object |
Activity Statistics Sub-Aggregator Type |
Measuring Component Business Object |
Activity Derived Snapshot Aggregator |
Measurement Business Object |
Measurement |
Measurement |
Service Type |
Electric |
Electric |
Interval Size |
24:00:00 |
24:00:00 |
Fallback Time Zone |
US Eastern Time |
US Eastern Time |
Consumptive/Subtractive |
Consumptive |
Consumptive |
Activity Aggregator Type |
Activity Processing Snapshot |
Activity Processing Derived Snapshot |
Aggregation |
Aggregation Horizon: 7 Aggregation Lag: 2 Aggregation Cut-Off Time: 12:00:00 |
Aggregation Horizon: 7 Aggregation Lag: 1 Aggregation Cut-Off Time: 12:00:00 |
Value Identifiers |
Sub-Aggregator Types |
N/A |
N/A |
Display Configuration |
Hours of Chart Data to Display: 480 Default Measurement Condition: Regular |
Master Aggregator Measuring Component Types:
Field |
Activity Processing Accumulation Aggregator |
Activity Aging Snapshot Aggregator |
ACT_PROC_ACC_AGG |
ACT_AGN_SNAP_AGG |
Description |
Activity Statistics Master Aggregator Type |
Measurement |
Measurement |
Service Type |
Electric |
Electric |
Interval Size |
24:00:00 |
24:00:00 |
US Eastern Time |
US Eastern Time |
Consumptive |
Consumptive |
Activity Processing |
Activity Aging Snapshot |
Aggregation |
Aggregation Horizon: 5 Aggregation Lag: 2 Aggregation Cut-Off Time: 12:00:00 |
Value Identifiers |
N/A |
Hours of Chart Data to Display: 720 Default Measurement Condition: Regular |
Create Activity Aggregator Measuring Components
Create an activity aggregator measuring component for each activity type you wish to capture for each measuring component type you created above. For example, if you wanted to capture statistics for request orchestration activity types (such as Enable Service, Disable Service, and so on) for the above measuring component types, you would create a total of 24 measuring components, as follows:
Aggregation Dimensions — Activity Type |
Aggregation Dimensions — Service Type |
Back to Back Orchestrator |
Electric |
Electric |
Electric |
Electric |
Cut for Non Payment Orchestrator |
Electric |
Electric |
Electric |
Electric |
Disable Service |
Electric |
Disable Service |
Electric |
Disable Service |
Electric |
Disable Service |
Electric |
Enable Service |
Electric |
Enable Service |
Electric |
Enable Service |
Electric |
Enable Service |
Electric |
Exchange Meter |
Electric |
Exchange Meter |
Electric |
Exchange Meter |
Electric |
Exchange Meter |
Electric |
Reconnect Service for Payment Orchestrator |
Electric |
Electric |
Electric |
Electric |
If you wanted to also capture statistics for smart meter commands or field task types, you would need to create activity aggregator measuring components for each individual command or field task type for each measuring component type.
If you are creating service order activities from multiple initiating systems (such as a customer information system and a network management system), you would need to create separate sets of activity aggregator measuring components for each initiating system.
Configure the Service Order Management Master Configuration
You can access the Master Configuration portal by selecting Admin, then General, then Master Configuration.
Select the Service Order Management Master Configuration.
Use the Add button beside the record to configure for the first time. If a record has already been added, then click the Edit button instead. Use the embedded help to guide you through the meaning of each configuration field.
Create an Activity for each Measuring Component Type
For example, if you configured measuring component types for both "Electric" and "Water" service types, you would create eight activities (two of each of the types listed above).
Use the following procedure to create these activities:
Select Menu, then Communication, then Activity, then Add. The Select Type page opens.
Select "Activity Statistics Aggregator Creator" from the Activity Type drop-down list and click OK. The Activity Statistics Aggregator Creator page opens.
Select the appropriate measuring component type from the Aggregator Measuring Component Type drop-down list.
Select the appropriate service type ("E, "Water", and so on) from the Service Type drop-down list.
Click Save.
See Maintaining Activities in the Business User Guide for more information about creating and maintaining activities.
Aggregation and Batch Processing
The Service Order Management dashboards are based on aggregated data, and are configured to be refreshed daily. To refresh the data used in the dashboard, the following aggregation and batch processes should be processed in sequence each day.
Dimension Scanning
D1-ADS (Aggregation Dimension Scanner Monitor): Used to transition "Activity Statistics Aggregator Creator" activities (created above) to the "Scan" state which checks for aggregator measuring components based on each measuring component type for each combination of dimensions. If needed, this process creates additional aggregator measuring components.
Use the following parameters when running this batch process:
Measuring Component Maintenance Object (maintenanceObject): D1-ACTIVITY
Restrict by Batch Code (isRestrictedByBatchCode): true
Restrict to Business Object (restrictToBusinessObject): D1-ActivityStatsAggtorCreator
Restrict by Status Code (restrictToBOStatus): ACTIVE
Note: Dimension scanning can also be performed manually by clicking Scan on the individual activities in the Activity portal.
Aggregation
D1-ACTAG (Activity Statistics Aggregation Monitor): Used to aggregate activity data (via aggregator measuring components) to be displayed in the Service Order Management dashboards.
Restrict to Business Object (restrictToBusinessObject): Aggregator Measuring Component business object, based on the measuring component types configured earlier:
D1-ActivityAgingSnapAggtor (Activity Aging Snapshot Aggregator)
D1-ActivityProcsAggregator (Activity Processing Accumulation Aggregator)
D1-ActivityProcDerivedSnapAgg (Activity Derived Snapshot Aggregator)
D1-ActivityProcSnapAggtor (Activity Processing Snapshot Aggregator)
Override Maximum Errors (maxErrors): 1000
Note: Aggregation can also be performed manually by clicking Update Statistics on the Activity Statistics dashboard zone.
