Rolling Demand
This rule is used to calculate rolling demand for all of the service points on the usage subscription. Demand is calculated from consumption. In electric service markets, these are typically represented by kilowatts (kW) and kilowatt hours (kWh) respectively, where demand values are calculated by multiplying consumption interval values by the number of intervals per hour. For example, the demand associated with a fifteen (15) minute interval value of 25kWh would be 100kW (25 x 4 intervals per hour).
Interval Data Retrieval Parameters
This rule can be configured to use specific data either directly from a specific device and measuring component on the service point or calculated from more than one devices and/or measuring components on the service point. Each type of data is referred to as a "channel" of data. For example, a service point with solar panels might have separate channels for "Consumed" and "Generated" usage, and the rule could be configured to use data from either or based on calculations involving both.
Parameters used to retrieve interval data for this rule include:
Check Missing Intervals: A flag that indicates if the rule should check for missing intervals during the calculation period.
No Meter Condition: The measurement condition assigned to intervals inserted to fill gaps during periods in which when no meter is installed. If not set, the measurement condition defaults to "No Read - System" (100000).
SP Device Filter: An algorithm used to filter the service point device configuration that will be processed by the rule.
Common UOM: The unit of measure that is common among the multiple channels of data used by the rule, if applicable
Common Interval Size: The interval size used to align service point data of different interval sizes. For instance, if a service point has channels measuring data in both 1-hour and 15-minute intervals, setting this to 01:00:00 (1 hour) would scale the 15-minute data to hourly intervals.
Channels: A list of the data channels measured at the service point. Each should be assigned a variable name and the appropriate UOM, TOU, and SQI.
Aggregation Method: The method by which data from multiple channels will be aggregated. Channels can be combined using a simple formula or using a conditional formula.
To define a single channel for the rule to use, configure the "Vector 1 (IV1)" variable in the Channels section and reference that variable in a simple formula.
To configure the rule to use multiple channels, define each as a variable in the Channels section and configure either a simple or conditional formula to perform any needed evaluations or calculations on the channels.
Defining Formula Operands
Operands used in both simple and conditional formulas are defined in the Operand Lookup (D1-CoincidentPeakOperandLookup) extendable lookup. Operands used to represent channels should use the values in parentheses in the Variables drop-down list in the Channels section. For instance, the operand for "Vector 1 (IV1)" should be "IV1", the operand for "Vector 2 (IV2)" should be "IV2", and so on.
Operands can also be simple formulas based on the variables defined in the Variables drop-down list in the Channels section. For instance, a simple formula in which the values from Vector 1 are subtracted from the values in Vector2 could be defined as "IV2 - IV1".
Calculation Modes
This rule has two main modes: calculating rolling demand for a usage subscription based on either a rolling consumption total (Rolled Total) or rolling consumption average (Rolled Average), or calculating the coincident peak among all of the service points on a usage subscription based on either a rolling consumption total (Rolled Total - Coincident Peak) or rolling consumption average (Rolled Average - Coincident Peak). The coincident peak calculation can be performed on either all readings, or those designated as "on-peak" or "off-peak" via time of use mapping using the Coincident On-Peak or Coincident Off-Peak function, See Defining Time of Use Mapping Options for more information about time of use mapping.
The number of intervals in the rolling total or rolling average is determined via rule configuration. The Roll Interval Size parameter (in the Calculation Details section) divided by the Common Interval Size parameter (in the Interval Data Retrieval Parameters section). For example, if Roll Interval Size was 01:00:00 (1 hour) and the Common Interval Size was 00:15:00 (15 minutes), the rolling total or average would be based on sets of 4 intervals (1 hour divided by 15 minutes).
Rolled Demand Total
The "Rolled Demand Total" Roll Calculate Function identifies the peak demand for the usage subscription based on a rolling consumption total.
For example, the table below lists sample hourly interval data for two service points belonging to single usage subscription for a 12 hour calculation period. This table includes the following:
Date/Time: The date and time of each interval
Service Point n: The kWh value for each interval at a specific service point
Total: The combined total of consumption at the usage subscription's service points
Rolling Total: The rolling total of 4 total values (based on a Roll Interval Size of 01:00:00 (1 hour) and Common Interval Size of 00:15:00 (15 minutes))
Demand: The demand calculated from the rolling total (calculated by multiplying the running total by the number of intervals per hour - in this example the total is the same as the demand because this is hourly data).
This rule would identify the highest demand for the usage subscription during the calculation period (indicated in bold).
Date/Time |
Service Point 1 |
Service Point 2 |
Total |
Rolling Total |
Demand |
10/27/2022 12:00 PM |
12 |
11 |
23 |
10/27/2022 1:00 PM |
10 |
12 |
22 |
10/27/2022 2:00 PM |
11 |
13 |
24 |
10/27/2022 3:00 PM |
13 |
13 |
26 |
95 |
95 |
10/27/2022 4:00 PM |
14 |
14 |
28 |
100 |
100 |
10/27/2022 5:00 PM |
13 |
13 |
26 |
104 |
104 |
10/27/2022 6:00 PM |
12 |
13 |
25 |
105 |
105 |
10/27/2022 7:00 PM |
11 |
12 |
23 |
102 |
102 |
10/27/2022 8:00 PM |
12 |
13 |
25 |
99 |
99 |
10/27/2022 9:00 PM |
13 |
14 |
27 |
100 |
100 |
10/27/2022 10:00 PM |
12 |
14 |
26 |
101 |
101 |
10/27/2022 11:00 PM |
12 |
12 |
24 |
102 |
102 |
This rule would return the following values in the usage transaction service quantities list, which represents the peak demand value during the calculation period:
Date/Time |
Demand |
105 |
Rolled Demand Total - Coincident Peak / Rolled Demand Total - Coincident On Peak / Rolled Demand Total - Coincident Off Peak
The "Rolled Demand Total - Coincident Peak / Rolled Demand Total - Coincident On Peak / Rolled Demand Total - Coincident Off Peak" Roll Calculate Function identify the coincident peak demand for all of the service points on the usage subscription. The "coincident peak" is the time at which the combined values of multiple service points is the highest (which is not necessarily the peak for each individual service point). The coincident peak demand is the demand based on the rolling total at the coincident peak.
The data used in the calculation is based on the specific Roll Calculate Function selected:
Total - Coincident Peak: Evaluates all measurements matching the configured unit of measure
Total - Coincident On Peak: Evaluates measurements matching the configured unit of measure that falls with the "on peak" TOU period defined in the Results section based on a specified TOU Map Template.
Total - Coincident Off Peak: Evaluates measurements matching the configured unit of measure that falls with the "off peak" TOU period defined in the Results section based on a specified TOU Map Template.
This rule would identify the highest total for all of the service points within the calculation period (indicated in bold).
Date/Time |
Service Point 1 |
Service Point 2 |
Total |
Rolling Total |
Demand |
12 |
11 |
23 |
10 |
12 |
22 |
11 |
13 |
24 |
13 |
13 |
26 |
95 |
95 |
14 |
14 |
28 |
100 |
100 |
13 |
13 |
26 |
104 |
104 |
12 |
13 |
25 |
105 |
105 |
11 |
12 |
23 |
102 |
102 |
12 |
13 |
25 |
99 |
99 |
13 |
14 |
27 |
100 |
100 |
12 |
14 |
26 |
101 |
101 |
12 |
12 |
24 |
102 |
102 |
This rule would return the following values in the usage transaction service quantities list, which represent the demand at the coincident peak:
Date/Time |
Coincident Peak Demand |
100 |
Rolled Demand Average
The "Rolled Demand Average" Roll Calculate Function identifies the peak demand for the usage subscription based on a rolling average (calculated from the rolling total).
Rolling Average: The rolling average of 4 total values (based on a Roll Interval Size of 01:00:00 (1 hour) and Common Interval Size of 00:15:00 (15 minutes))
Demand: The demand calculated from the rolling average (calculated by multiplying the rolling average by the number of intervals per hour - in this example the total is the same as the demand because this is hourly data).
Date/Time |
Service Point 1 |
Service Point 2 |
Total |
Rolling Total |
Rolling Average |
Demand |
12 |
11 |
23 |
10 |
12 |
22 |
11 |
13 |
24 |
13 |
13 |
26 |
95 |
23.75 |
23.75 |
14 |
14 |
28 |
100 |
25 |
25 |
13 |
13 |
26 |
104 |
26 |
26 |
12 |
13 |
25 |
105 |
26.25 |
26.25 |
11 |
12 |
23 |
102 |
25.5 |
25.5 |
12 |
13 |
25 |
99 |
24.75 |
24.75 |
13 |
14 |
27 |
100 |
25 |
25 |
12 |
14 |
26 |
101 |
25.25 |
25.25 |
12 |
12 |
24 |
102 |
25.5 |
25.5 |
Date/Time |
Demand |
26.25 |
Rolled Demand Average - Coincident Peak / Rolled Demand Average - Coincident On Peak / Rolled Demand Average - Coincident Off Peak
The "Average - Coincident Peak / Average - Coincident On-Peak / Average - Coincident Off-Peak" Calculate Function identify the coincident peak demand for all of the service points on the usage subscription. The "coincident peak" is the time at which the combined values of multiple service points is the highest (which is not necessarily the peak for each individual service point). The coincident peak demand is the demand based on the rolling average at the coincident peak.
Rolled Demand Total - Coincident Peak: Evaluates all measurements matching the configured unit of measure
Rolled Demand Total - Coincident On Peak: Evaluates measurements matching the configured unit of measure that falls with the "on peak" TOU period defined in the Results section based on a specified TOU Map Template.
Rolled Demand Total - Coincident Off Peak: Evaluates measurements matching the configured unit of measure that falls with the "off peak" TOU period defined in the Results section based on a specified TOU Map Template.
Date/Time |
Service Point 1 |
Service Point 2 |
Total |
Rolling Total |
Rolling Average |
Demand |
12 |
11 |
23 |
10 |
12 |
22 |
11 |
13 |
24 |
13 |
13 |
26 |
95 |
23.75 |
23.75 |
14 |
14 |
28 |
100 |
25 |
25 |
13 |
13 |
26 |
104 |
26 |
26 |
12 |
13 |
25 |
105 |
26.25 |
26.25 |
11 |
12 |
23 |
102 |
25.5 |
25.5 |
12 |
13 |
25 |
99 |
24.75 |
24.75 |
13 |
14 |
27 |
100 |
25 |
25 |
12 |
14 |
26 |
101 |
25.25 |
25.25 |
12 |
12 |
24 |
102 |
25.5 |
25.5 |
Date/Time |
Demand |
25 |
Notes and Examples
Notes and Recommendations
When using he "Coincident On Peak" or "Coincident Off Peak" Roll Calculate Function, you must specify either a TOU map (in the TOU Map field) or a TOU map template (in the On Peak Off Peak Schedule drop-down list) in the Calculation Details section, and specify the appropriate time of use period (On-Peak or Off-Peak, respectively) in the TOU field in the Results section.
A recommended practice is to configure a Service Quantity Identifier (SQI) to uniquely identify coincident peak data and specify it in the SQI field in the Results section.
Additional detail on the logic of this rule can be found in the Detailed Description of the D1-CALROLDEM Algorithm Type.
For help with the meaning of specific configuration fields, refer to the embedded help on the screen when adding or editing the rule.
Business Object
D1-CalcRollingDemandRule
Example Scenarios
Below are some example scenarios that can be achieved based on configuration of this rule.
Scenario 1: Calculate demand for services points based on rolling total (based on a single channel)
Interval Data Retrieval Parameters:
Check Missing Intervals: Yes
No Meter Condition: No Read - System
Common UOM: Kilowatt-Hour
Common Interval Size: 00:15:00
Channels:
Variable 1:
Variable Name: Variable 1 (IV1)
UOM: Kilowatt-Hour
Aggregation Method:
Formula Source: Simple Vector Formula
Simple Vector Formula: IV1
Calculation Details:
Roll Calculate Function: Rolled Demand Total
Roll Interval Size: 01:00:00
Results:
UOM: Kilowatt
TOU:
SQI:
Scenario 2: Calculate demand for service points based on rolling total (based on two channels)
In this scenario, the service point has two channels, one for consumed energy, and one for generated energy (from a solar panel). If the consumed value is greater than the generated value, subtract the generated value from the consumed value. If the generated value is greater than the consumed value, use zero (0).
Common Interval Size: 01:00:00
Channels:
Variable 1:
UOM: Kilowatt-Hour
TOU:
SQI: Consumed
Variable 2:
Variable Name: Variable 2 (IV2)
UOM: Kilowatt-Hour
TOU:
SQI: Generated
Aggregation Method:
Formula Source: Conditional Vector Formula
Conditional Vector Formula:
Sequence: 10
Left Operand: IV1
Criteria Operator: >
Right Operand: IV2
True Action: Apply True Formula
True Formula: IV1-IV2
False Action: Apply False Formula
False Formula: 0
Results:
UOM: Kilowatt
TOU:
SQI:
Scenario 3: Calculate demand for services points based on rolling average (based on a single channel)
Channels:
Variable 1:
UOM: Kilowatt-Hour
Aggregation Method:
Roll Calculate Function: Rolled Demand Average
Results:
UOM: Kilowatt
TOU:
SQI:
Scenario 4: Total - Coincident Peak (based on a single channel)
Channels:
Variable 1:
UOM: Kilowatt-Hour
Aggregation Method:
Roll Calculate Function: Rolled Demand Total, Coincident Peak
Results:
UOM: Kilowatt
TOU:
SQI: Coincident Peak
Scenario 5: Average - Coincident On Peak (based on a single channel)
Channels:
Variable 1:
UOM: Kilowatt-Hour
Aggregation Method:
Roll Calculate Function: Rolled Demand Average, Coincident, On Peak
Reference TOU Map by Template: Yes
On Peak Off Peak Schedule: <TOU map template>
Results:
UOM: Kilowatt
TOU: On Peak
SQI: Coincident On Peak
