Device Communication Base Package Business Objects
The adapter development kit base package includes the following communication business objects:
Business Object Name
Description
DG-ConnectDisconStateChgNtf
Generic - Connect/Disconnect State Change
DG-InitiateConnectDisconnect
Generic - Initiate Connect Disconnect
DG-InitiateMeterByMeterId
Generic - Initiate Meter Read By Meter ID
DG-InitiateOutageDetection
Generic - Initiate Outage Detection
DG-MeterAddNotification
Generic - Meter Add Notification
DG-MeterRemoveNotifcation
Generic - Meter Remove Notification
DG-OutageDetectEvtNotification
Generic - Outage Detection Event Notification
DG-ReadingChgNotification
Generic - Reading Changed Notification
Event Data Mapping
The head-end system event file format can map as follows into the business object, D1-DeviceEventMappingLookup:
Head-End System Flat File Field
Device Event Seeder BO Element
Comments
Transaction ID (from Header record)
External Source Identifier
This is the file name.
Device Identifier
External Device Identifier
Event Name
External Event Name
Event Creation Date/Time
Event Date/Time
Device Type
External Device Type
This element has no real bearing on the device type within MDM/SGG. Its valid values include (although the element itself is free-form):
Meter
Collector
Router
Service Location ID
External Service Location ID
Communication Module Serial Number
External Communication Module Identifier
Event Category ID
External Event Category
Event Severity
External Event Severity
Valid values include (although the element itself is free-form):
Alert
Information
Status Value
External Status Value
This represents additional information that relates to the event itself.
Status Date/Time
External Status Date/Time
The date & time at which the additional information referenced above had occurred.
