To Do Entries Created By Algorithms
There are To Do entries that are created by algorithm types supplied with the base package. The system supplies a To Do Type for each of these To Do entries that you may use.
If you want to take advantage of these types of entries for system algorithm types, you must do the following:
  • Create an algorithm:
    • This algorithm must reference the appropriate Algorithm Type.
    • These algorithms have a parameter of the To Do Type to be created. You should specify the To Do Type indicated in the table.
  • Plug the algorithm into the respective control table.
