Extensions Dashboard
This portal provides a high level summary of configuration entities that have been customized and extended to meet your business requirements. Included are customer owned entities and extended product owned entities. The portal is intended to be used by your implementation team to get an appreciation of areas that have been customized and may need to be reviewed or retested for various reasons.
Use Admin > Implementation Tools > Extensions Dashboard to navigate to the portal.
The following zones may appear as part of the portal's Main tab page
  • Extensions Summary. This zone provides a summary of customized entities by maintenance object. You may select a specific maintenance objects to review entities of this type.
  • Extension Entities. This zone lists customized entities of the selected maintenance object. It is only visible when a maintenance object is selected on the Extensions Summary zone.
  • Extension Details. This zone provides additional information as to which specific tables contain the custom owned content for the selected entity. It is only visible when a specific customized entity is selected.
  • Revision Control. This zone lists revisions made to the selected entity. It is only visible when revision information exists for the selected entity.
  • Configuration Migration. This zone lists CMA migration objects that applied changes to the selected entity. It is only visible when import information exists for the selected entity.
The following zone may appear as part of the portal's Review tab page
  • Duplicate Configurations. This zone highlights duplicate configuration issues that may rarely arise after an upgrade. Customers should use this information to adjust thir configuration accordingly.
