The Unique Identifier Area
Every object in the system must have a unique identifier. For some objects, typically administrative or control table data, the unique identifier is defined by the user creating the record. Other objects, typically master or transaction entities, the unique identifier is assigned by the system after the record is saved.
Where the identifier is displayed depends upon whether the ID is user-defined or system generated.
Pages displaying objects with a user defined identifier (such as To Do Type) typically display the identifier on the left along with a search button. For master and transaction tables, (such as To Do Entry) the unique identifier is typically found in the upper right corner of the screen along with a search button and is labeled as the entity’s ID. In this case, if there is an information string associated with the object, it is displayed on the left.
If the object being maintained has an associated context menu, a Context Menu Button is displayed appear.
