Maintaining Asset Inbound Communications
You use the Inbound Communication portal is used to display and maintain asset inbound communications.
Refer to About Asset Inbound Communications for additional functional information.
You can access the portal by selecting Menu, then Asset Management, then Asset Inbound Communication. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- Inbound Communication: This zone displays information for the asset inbound communication.
- Communication Tree: This zone displays a tree of objects related to the asset inbound communication, including its parent activity.
The following zones may appear as part of the portal's Log tab page:
- Inbound Communication Log: This zone displays the server logs for the asset completion event.
Note: The Inbound Communication portal may
display tabs and zones beyond those described here. These tabs and
zones are not used with Oracle Utilities Customer To Meter.
