Define Navigation Options
The base product includes navigation options for easy access to query and maintain an account’s direct debit mandate. To access these portals, add a new menu item to the account context menu (CI_​CONTEXTACCOUNT). This menu item should include two menu lines:
  • A context menu line for navigation to the direct debit mandate that references a navigation option of c1DirectDebitMandate. The system uses the account in context and attempts to find the most recent active mandate for the account. If a mandate exists, navigation is to the service task maintenance portal. If an active mandate does not exist, navigation is to the service task query portal.
  • A context menu line for adding a new direct debit mandate that references a navigation option of c1AddDirectDebitMandate.
