Setting Up Notification Types
Each notification type defines the controls and behavior for defining communication preferences and sending out notifications of that type.
There are two main categories of notification types: subscription and push. These behave differently. Refer to Push vs. Subscription Notification Types for more information.
Push notification types are configured as either parent or individual push notification types. A parent push notification type is used to define communication preferences and an individual push notification type is used to send notifications. Refer to Parent vs. Individual Push Notification Types for more information.
The base product supplies one Notification Type business object for message-based notification types and distinct business objects for template-based notification types. Refer to Template-Based vs. Message-Based Notification Types for more information. For more details, refer to the specifications for these business objects.
Some notification types require specific configuration. Refer to Designing Notification Types for more information.
To set up notification types, select Admin > Customer > Notification Type +.
This is a standard All-In-One Portal.
Refer to the embedded help text for more information.
