Rebate Claim Maintenance Object
When a customer files a claim for a rebate, a rebate claim will be created. The rebate claim maintenance object (MO) is used to support the definition of a claim. If your organization wishes to use this MO, you can either use the business object (BO) supplied in the base product or configure your own BO.
This MO provides the following functionality:
  • Depending on the utility's requirements, you can specify single or multiple items on the Rebate Claim. A separate maintenance object is provided to capture rebate claim lines for a rebate claim.
  • The standard characteristics collection is provided.
  • A log is provided. This can be used to track approval information for the claim, to capture adjustments created as the claim is processed, etc.
Fastpath:
For more information, about this MO and to review the business objects defined for this MO, navigate to Admin > Database > Maintenance Object > Search and view the MO C1-RCLAIM.
