Analytics Configuration
Customer Analytics Configuration Portal
Oracle Utilities Customer to Meter provides a Customer Analytics Configuration portal that holds information on the customer analytics configuration activities. This portal provides a summary of how much configuration has been set up, and also provides links and guidelines for the areas that need configuration, at the minimum, to successfully extract data from Oracle Utilities Customer Care and Billing to OUA. The following provides more information about this functionality.-
Customer Analytics Configuration Details – These data load parameters are used to extract, load, and transform data from Oracle Utilities Customer Care and Billing to Oracle Utilities Analytics. These parameters are used to identify and/or filter data when loading them into the data warehouse. Refer to the Oracle Utilities Customer Care and Billing section in the Configuring Oracle Utilities Analytics chapter of the Oracle Utilities Analytics Administration Guide for detailed information on each extract parameter.
Bucket Configuration List – This is a summary of the bucket configurations that are needed to classify and group extracted data within Oracle Utilities Analytics. The bucket configurations provide the ability to readily report and analyze data by buckets, or groups. Refer to the Oracle Utilities Customer Care and Billing section in the Configuring Oracle Utilities Analytics chapter of the Oracle Utilities Analytics Administration Guide for detailed information on each bucket configuration supported by Oracle Utilities Customer Care and Billing.
Characteristic Mapping
Oracle Utilities Customer Care and Billing has identified the objects for which characteristic extraction is supported. This includes mapping the source characteristic entity to thetarget dimension, and defining which target columns are allowed to be mapped for which target dimension. The following table shows the supported mapping.
 Object  |
 Supported Target Dimension  |
 Supported Target Columns  |
 Account Characteristic  |
 Account Dimension  |
 User Defined Fields 6 - 15  |
 Person Characteristic  |
 Person Dimension  |
 User Defined Fields 1 - 6  |
 Premise Characteristic  |
 Premise Dimension  |
 User Defined Fields 6 - 18  |
 Address Dimension  |
 User Defined Fields 7 - 16  |
 Service Agreement Characteristic  |
 Service Agreement Dimension  |
 User Defined Fields 9 - 19  |
Meter Analytics Configuration Portal
Analytics - Oriented Master Configuration: These data load parameters are used to extract, load, and transform data from Oracle Utilities Meter Data Management to Oracle Utilities Analytics. They are used to identify and/or filter data when loading them into the data warehouse. Refer to the Oracle Utilities Meter Data Management section in the Configuring Oracle Utilities Analytics chapter of the Oracle Utilities Analytics Administration Guide for detailed information on each extract parameter
Analytics - Oriented Extendable Lookup List: The meter data analytics related Extendable Lookup Business Objects are listed in this section. It provides a navigation link to the extendable Lookup Maintenance portal where the lookup values can be configured. Refer to the Oracle Utilities Meter Data Management section in the Configuring Oracle Utilities Analytics chapter of the Oracle Utilities Analytics Administration Guide for detailed information on meter data analytics related extendable lookups.
Service Point Configuration List: This lists the service point types within the system and indicates for each whether or not the meter analytics configuration has been setup. It provides a navigation link to the service point type where the necessary configuration can be setup or modified. Refer to the Oracle Utilities Meter Data Management section in the Configuring Oracle Utilities Analytics chapter of the Oracle Utilities Analytics Administration Guide for further information.
Batch Controls
 Batch Code  |
 Name / Description  |
 D1-SPSDL  |
 Service Point Snapshot Download  |
 D2-DUGDL  |
 Usage Subscription Usage Group Download  |
 D2-MVREF  |
 Materialized View Refresh  |
 D2-USGDL  |
 Service Point Usage Snapshot Download  |
 D2-UUSDL  |
 SP Unreported Usage Snapshot Download  |
 D2-VEEDL  |
 SP VEE Exception Snapshot Download  |
References
Oracle Utilities Analytics Admin Guide
Oracle Utilities Analytics Dashboards for Oracle Utilities Customer Analytics, Revenue Analytics and Credit & Collections Analytics Metric Reference Guide
Oracle Utilities Analytics Dashboards for Oracle Utilities Exception Analytics Metric Reference Guide
Oracle Utilities Analytics Dashboards for Oracle Utilities Meter Data Analytics Metric Reference Guide
Oracle Utilities Extractors and Schema for Oracle Utilities Customer Care and Billing Data Mapping Guide
Oracle Utilities Extractors and Schema for Oracle Utilities Meter Data Management Data Mapping Guide
