Inbound Web Services
Inbound web services define the details of how messages are received from an external system. This includes incoming usage and device events, as well as messages sent from the L+G Command Center in response to a command request.
The following inbound web services must be configured in your system. If these are not present in your configuration, add them. Refer to the Oracle Utilities Application Framework documentation for more information about creating inbound web services.
Inbound Web Service Name
Description
D1-BulkRequestHeader
Bulk Request Header
D1-BulkRequestUpdate
Bulk Request Update
D1-BulkResponse
Bulk Response
D1-DeviceEventSeeder
Device Event Seeder
D1-InitialLoadIMD
IMD Seeder
D1-PayloadErrorNotif
Payload Error Notification
D1-PayloadStatistics
Payload Statistics
D1-PayloadSummary
Payload Summary
D3-ConDisconStChgNotification
Initiate Connect Disconnect Response
D3-CIMMeterReadingsResponse*
CIM Meter On Demand Read Response
D3-CIMPingResponse
CIM Ping Respose
D3-ReadingChangedNotification*
Reading Changed Notification
D3-ScheduleDemandResetResponse
Scheduled Demand Reset Response
*The Landis+Gyr adapter supports both MultiSpeak and CIM On Demand Read commands. You only need to configure the inbound service for the protocol you wish to use.
Note: The following apply to all of the above inbound web services:
Message Options
  • Trace: No
  • Debug: No
  • Active: Yes
Operations
  • Operation Name: Same as web service name
  • Schema Type: Business Object
  • Schema Name: Applicable business object code
  • Transaction Type: Add
