On Demand Read
OnDemandRead interrogates a meter for the usage at the current point in time.
Composite Properties
Property Name
Default Value
Description
CB_​ServerCallbackEndpoint
http:/[SERVER_​NAME]/soa-infra/services/DG/OnDemandRead/CB_​Server
The default endpoint to which MultiSpeak should send the asynchronous CB_​Server callback
IsExecutingOnDemandReadRequestReceived
true
Controls whether the Request Received callout executes
IsExecutingOnDemandReadRequestReceivedResponse
true
Controls whether the Request Received Completed callout executes
IsExecutingReadingChangedNotification
true
Controls whether the Reading Changed Notification arrival callout executes
CallbackTimeoutYears
0
The number of years to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service.
CallbackTimeoutMonths
0
The number of months to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service.
CallbackTimeoutDays
0
The number of days to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service.
CallbackTimeoutHours
0
The number of hours to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service.
CallbackTimeoutMinutes
0
The number of minutes to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service.
CallbackTimeoutSeconds
45
The number of seconds to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service.
Composite WSDLs
Composite
Description
OnDemandReadService
Entry point for the OnDemandRead operation. After a synchronous reply, further updates will be sent to the specified location asynchronously using DG-ReadingChangedNotification.
CB_​ServerService
MultiSpeak WSDL hosted to receive asynchronous ReadingChangedNotification callbacks from the head end system.
MR_​ServerProxy
Reference describing the proxy used to invoke the head end system to initiate a On Demand Read.
MR_​ServerCallout
Reference describing the process callout used when initiating a On Demand Read.
CB_​ServerCallout
Reference describing the process callout used when the asynchronous callback from the head end system arrives.
AuxilaryRoutines
Reference to common helper routines in the Common composite.
DG-ReadingChangedNotificationXAI
A reference to an inbound web service capable of processing asynchronous results from a On Demand Read request.
Process Flow
  1. SGG/OUAF invokes InitiateMeterReadingsByMeterID operation using OnDemandReadService.
  2. Composite properties are loaded. Local variables are initialized.
  3. Test whether the input includes a expiration time
    • If Yes: Use AuxilaryRoutines to compute timeout
    • If No: Use composite properties and AuxiliaryRoutines to compute expiration time
  4. Both the Header and Body inputs are transformed to MultiSpeak format.
  5. If required, execute a process callout in MR_​ServerCallout. Assign updated data to head end request.
  6. Add a callback URL to the head end request. This is the endpoint the head end will use to send the results.
  7. Invoke InitiateMeterReadingsByMeterID via the MR_​ServerProxy to the head end system.
  8. If required, execute a process callout in MR_​ServerCallout. Assign updated data to head end response.
  9. Transform Header and Body head end responses to SGG/OUAF format
  10. Reply to SGG/OUAF with synchronous results
  11. Check for ErrorObject in the head end response.
  12. If error object not found
    • Await asynchronous response from head end for the period of expiration time calculated during start of this flow
      • Receive ReadingChangedNotification from CB_​ServiceService.
      • Generate reply with no errors for ReadingChangedNotification.
      • Synchronously reply to the head end.
      • If required, execute a process callout in CB_​ServerCallout. Assign updated data to the incoming request.
      • Transform Header and Body of incoming request to OUAF inbound web service format described in DG-ReadingChangedNotificationXAI.
      • If request contains responseURL
        • Invoke the inbound web service on given responseURL with the transformed incoming request.
      • Else
        • Invoke the inbound web service on definedURL with the transformed incoming request.
