Viewing Erasure Configuration
The erasure configuration may be viewed in the Maintenance Object Configuration All-in-One portal. It provides the ability to view the maintenance objects that are marked as eligible for erasure and maintain their erasure configuration entries in a single place.
To view a list of the eligible MOs, open Admin > Implementation Tools > Maintenance Object Configuration.
In the Object Erasure Configuation zone, press the edit icon to open a window in which the configuration values for that maintenance object can be changed.
Refer to The Approach to Implementing Object Erasure for an overview of object erasure configuration.
