Defining Fields
This portal is used to view and maintain information about a field. For product owned fields, you may use this portal to override the label of a field on the various pages in the system.
You can access the portal from the . You are brought to a query portal with options for searching for a specific field. Once a field has been selected you are brought to the maintenance portal to view and maintain the selected record.
Note: When introducing a new record, carefully consider its naming convention. Refer to
System Data Naming Convention for more information.
Refer to Fields for more information.
The following zones may appear as part of the portal's Main tab page
- Field. This zone provides information about the selected field.
 - Tables Using Field. This zone lists tables referencing the field. It is not visible for work fields.
 - Lookup Values. This zone lists and maintains valid values for the selected lookup field. The zone is only visible when the selected field is a lookup field.
The following zone may appear as part of the portal's References tab page
- Field References. This zone list various configuration entities referencing the current field.
