Conversion Entity Dashboard
This portal provides an overview of a maintenance object’s conversion configuration along with information related to its current status and progress within the overall conversion process.
Refer to Understanding Conversion for more information.
You can access the portal from the You are brought to a query portal with options for searching for a specific maintenance object that is eligible for conversion. Once a maintenance object has been selected you are brought to the conversion entity dashboard portal to review the information for the selected record.
The following zones may appear as part of the portal's Main tab page.
- Tables. This zone provides information about tables that belong to the maintenance object and are marked as eligible for conversion.
 - Batch Controls. This zone lists the conversion batch controls defined for the maintenance object in the order they should be executed within the conversion process along with current execution details if any.
 - Error Summary. This zone provides a summary of all conversion errors related to the maintenance object.
 - Duplicate Keys. This zone lists duplicate legacy keys that need to be resolved by the key assignment conversion process.
The Errors tab page provides a query zone that allows you to review conversion errors related to the maintenance object by various criteria.
