Configuring a New Infrastructure Process Type
In order to configure a new process type, navigate using Admin > Implementation Tools > Infrastructure Process Type. Use the Infrastructure Process Step all-in-one portal to view existing process types.
The following points provide information about creating a new Infrastructure Process Type.
When creating a new process type, a business object has to be selected first. The Infrastructure Process Type BO contains information necessary for the Infrastructure Process that references that process type. You can use existing Infrastructure Process Type BOs or create new BOs according to your business requirements.
The Related Transaction BO references the Infrastructure Process BO. The process BO contains the business logic associated with the process. This includes the orchestration of the process steps. The process BO also contains information that is shared by step business logic during the process. For example, a process BO that handles migration of data between product environments can have a buffer that will hold the information pulled from the source environment using one step so that another step can use it to push that to the target environment. You can use existing Infrastructure Process BOs or create new BOs according to your business requirements.
The Process Type Steps section includes a collection of step types. The sequence of steps has to be unique and this will be sequence of execution.
The Infrastructure Process Type Details section represents additional information that is required for the specific process type BO.
