Configuring MV90 Extendable Lookups
This section outlines some of the extendable lookups that must be configured for use with the MV-90 Adapter for Itron. Refer to the Oracle Utilities Application Framework documentation for more information about working with extendable lookups.
Interval Status Code to Event Mapping
The MV-90 Adapter for Itron does not accept device events from an MV-90 system, but can create device events based on specific interval status codes in an incoming usage reading. The MV-90 Interval Status Code to Event Mapping extendable lookup is used to determine which type of device event business object to instantiate when creating device events based on interval status codes received with usage from the MV-90 system.
Each value defined for the Interval Status Code to Event Mapping extendable lookup should include the following:
MV90 Interval Status: The interval status code used by the MV-90 system
Description: A description of the MV-90 interval status code
Event Duration Mode: The duration type for the event. Can be either “Individual” or “Continuous” (used for events with a duration, such as an outage).
Device Event Type: The Device Event Type for the device event created for this interval status code. For status codes with an Event Duration Mode of “Continuous” this is the start event, or the first of the paired events created for this status code.
End Event Type: The Device Event Type for the “end” device event created for this interval status code. For status codes with an Event Duration Mode of “Continuous” this is the end event, or the last of the paired events created for this status code.
Example: The MV-90 “Low Voltage” status code could be configured to create a “Low Voltage” device event as follows:
MV90 Interval Status: <MV-90 interval status code for low voltage>
Description: Low Voltage detected for meter
Event Duration Mode: Individual
Device Event Type: Low Voltage
End Event Type: N/A
Example: The MV-90 “Power Outage” status code could be configured to create a “Last Gasp” device event, and a “Power Restoration” event as follows:
MV90 Interval Status: <MV-90 interval status code for outage>
Description: Outage
Event Duration Mode: Continuous
Device Event Type: Last Gasp
End Event Type: Power Restoration
UOM Code to Standard UOM Code Mapping
Usage received from a utility’s head-end system may use utility-specific unit of measures (UOMs). These custom UOMs must be mapped to standard UOM codes. The UOM Code to Standard UOM Mapping extendable lookup is used for this purpose. Each value defined for the UOM Code to Standard UOM Mapping extendable lookup should include the following:
Head-end UOM: The unit of measure code used by the head-end system.
Unit of Measure: The unit of measure defined in the system.
Description: A description of the unit of measure code.
Other Extendable Lookups
Business Object Name |
Description |
D5 - ChanelStatusCodeLookup |
MV-90 Channel Status Code Lookup |
D5-IntStsCdToCndMapPrLookup |
Condition Mapping with Priority |
