Field Encryption
The system supports encryption of certain sensitive fields in the database. This support includes the ability to capture hash values of encrypted data for searching purposes.
Refer to Application Encryption to understand how to configure which fields you want to encrypt.
The sections in this topic provide more information about the defining the encryption and hash key values and the key rotation support.
Symmetric Key
The product provides an AES Symmetric Key business object. It generates an encryption key using an AES 256 algorithm.
When defining a key ring for this business object, you provide a 3-character "wrap" prefix that is unique across key rings for the 'symmetric key' class. This aids in key rotation, described below.
The business object supports key rotation with respect to the keys. See the section below for more information about key rotation.
Once your symmetric key ring is defined and you have at least one active key, you can configure the fields that you want to encrypt and reference this key ring in the configuration. Refer to Application Encryption for more information.
Hash Key
The product provides an HMAC Hash Key business object. It generates an HMAC key and stores it in PEM format.
When defining a key ring for this business object, you provide a 3-character "wrap" prefix that is unique across key rings for the 'hash key' class. This aids in key rotation, described below.
Once your hash key ring is defined and you have at least one active key, for encrypted fields that support a hash value, you can reference this key ring in the configuration. Refer to Application Encryption for more information.
Key Rotation
Defining your encryption and hash keys using key rings allows for key rotation.
  • When the system encrypts the data or creates the hash field, it uses a marker so that the system knows what key ring and key were used to encrypt / hash the data. Data is encrypted / hashed with the current Active key.
  • If your organization wants to introduce a new key for either your symmetric key ring or your hash key ring, use the Generate Key button to create a new key. Click the Activate button adjacent to that Key to make it the key to use for all data that gets added or updated going forward. The previous key is marked Inactive.
  • All records added or updated going forward use the new key.
  • To rotate the keys across all the existing data encrypted / hashed with the previous key, you need to submit a batch. Refer to Mass Key Rotation for more information.
Key Ring Rotation
The respective business objects for the symmetric key ring and the hash key ring define the algorithms to use for generating the key. If there comes a point where you want to use a different algorithm for generating the symmetric encryption key or the hash key, a new business object is needed so that the new desired algorithm can be defined. The following points highlight the steps needed to change the key generation algorithm.
  • Define the new business object for the use case (symmetric encryption key or hash key). Ensure that the algorithm related to the Generate Key state has the desired key generation logic. This business object should include a field for the 'wrap prefix', similar to the delivered product business objects for the symmetric key ring or hash key ring.
  • Define a new key ring for the new business object and be sure to choose a different wrap prefix value. This is needed for key rotation.
  • Generate a key for the key ring and activate it.
  • Go to the Feature Option Configuration and update the keyRing or hashKeyRing references for all the entries to point to the new key ring.
  • All records added or updated going forward use the new key ring and its active key.
  • To rotate the keys across all the existing data encrypted / hashed with the previous key ring and its key, you need to submit a batch. Refer to Mass Key Rotation for more information.
