Defining Product Metric Type
Product metric types are defined by the product. To view the product metric types, open Admin > System > Product Metric Type.
Use the Product Metric Type Query portal to search for a product metric type. Once a record is selected, you are brought to the maintenance portal to view and maintain the selected record.
For information about the data defined on the product metric type, refer to embedded help.
