Jump to main content
Oracle Utilities Rate Cloud Service
  1. Home
  2. Oracle Utilities Rate Cloud Service User Guides
  3. Oracle Utilities Cloud Service Foundation
  4. Cloud Service Foundation
  5. Oracle Cloud Infrastructure Identity and Access Management Integration
  6. Configuring Identity and Access Management Integration
  7. Customizing the Integration
  • Oracle Utilities Rate Cloud Service User Guides
    • Business User Guide
    • Administrative User Guide
    • Oracle Utilities Cloud Service Foundation
      • Cloud Service Foundation
        • Process Automation Tool
        • Data Conversion Support for Cloud Implementations
        • Batch Scheduler for Cloud Implementations
        • Batch Queues Overview
        • Batch Alerts
        • Oracle Cloud Infrastructure Identity and Access Management Integration
          • Identity and Access Management Integration Overview
          • Configuring Identity and Access Management Integration
            • Configuring Just In Time User Provisioning
            • Customizing the Integration
              • Override Default Access Level
              • Override Logic to Determine Template User
        • Oracle Cloud Object Storage
        • Maintaining Customer Code
The product is delivered with out-of-the-box support for Just in Time User Provisioning with Coarse-Grained Authorization. Possible customization scopes are:
  • Customize the default access level for Coarse-Grained Authorization. See Override Default Access Level for details.
  • Configure the Just in Time User Provisioning with Fine-Grained Authorization.
© Oracle   About Oracle   Contact Us   Products A-Z   Terms of Use and Privacy
