Base Package Migration Plans
The C1-owned base package provides a large number of migration plans to support migrating configuration and/or administration data from one environment to another.
Use the following procedure to access the base package migration plans:
  1. Navigate to Admin > Implementation Tools > Migration Plan > Search.
  2. Enter “C1” in the Migration Plan field.
  3. Click Refresh.
  4. Select a migration plan in the search results list. The details of the selected migration plan are displayed in the Migration Plan portal.
The C1-owned base package plans can also be used as a basis for custom migration plans. To create a custom migration plan, select a plan to base the custom migration plan on, click the Duplicate button, and define the custom plan to meet the implementation’s requirements as described in Defining a Migration Plan in the Oracle Utilities Application Framework Administration Guide.
