Quote Information
Global Extract Information (0010) Record Definition
This is a "header" record that contains information about the extract run as a whole.
Please be aware that if you do not sort your extract file by CIS Sort Key after it is produced, this record will physically be the last record on the extract file.
Field Name
Format
Source/Value/Description
BATCH_​CD
A8
Batch Control Code of the extract process.
BATCH_​NBR
N10
Batch Number of the extract process
BATCH_​RERUN_​NBR
N10
Batch Rerun number of the extract process.
QTE_​CNT
N10
Count of quotes on this extract.
EXTRACT_​DTTM
A26
System time of extraction.
QUOTE_​ID_​START
A12
This is only used when a quote is produced as a result of an online request (from Quote - Main). It contains the Quote Id to extract.
QUOTE_​ID_​END
A12
THREAD_​NBR
N10
This field is only used if quotes are extracted in batch. It contains the thread number in which the quote was extracted.
THREAD_​CNT
N10
This field is only used if quotes are extracted in batch. It contains the total number of threads that were extracted.
Top of Page
Quote (0100) Record Definition
Field Name
Format
QUOTE_​ID
A12
CI_​QUOTE
ACCT_​ID
A10
CI_​QUOTE
EXPIRE_​DTTM
A26
CI_​QUOTE
QUOTE_​STAT_​FLG
A2
CI_​QUOTE
CURRENCY_​CD
A3
CI_​ACCT
CUR_​SYMBOL
A4
CI_​CURRENCY_​CD
ENTITY_​NAME1
A64
CI_​QUOTE_​RTG. Mailing Entity Name1.
ENTITY_​NAME2
A64
CI_​QUOTE_​RTG. Mailing Entity Name2.
ENTITY_​NAME3
A64
CI_​QUOTE_​RTG. Mailing Entity Name3.
ADDRESS_​SBR
A361
CI_​QUOTE_​RTG. Refer to its components in a later section.
EMAILID
A254
CI_​QUOTE_​RTG
PHONE-FAX
A64
CI_​QUOTE_​RTG
Top of Page
Quote Detail (0200) Record Definition
Field Name
Format
QUOTE_​DTL_​ID
A12
CI_​QUOTE_​DTL
SA_​ID
A10
CI_​QUOTE_​DTL
TOTAL_​AMT
N13.2
CI_​BSEG_​CALC. Sum of all calculation amounts (quote detail's bill segments).
PREMISE_​ID
A10
CI_​SA (Characteristic Premise)
ADDRESS_​SBR
A361
CI_​PREM. Refer to its components in a later section.
SA_​TYPE_​DESCR
A60
CI_​SA_​TYPE_​L
SVC_​TYPE_​CD
A30
CI_​SVC_​TYPE_​L
SA_​VERSION
N5
CI_​QUOTE_​DTL
QTE_​DTL_​SA_​VERSION
N5
CI_​QUOTE_​DTL
RS_​DESCR
A60
CI_​RS_​L. Description of Rate effective on SA start date.
Top of Page
SA Terms and Conditions (0300) Record Definition
Field Name
Format
START_​DT
A10
CI_​SA_​TC
END_​DT
A10
CI_​SA_​TC
TC_​TYPE_​CD
A12
CI_​TC
DESCR
A60
CI_​TC_​L
TC_​TYPE_​TXT
A2000
CI_​TC_​L
Top of Page
Bill Segment (0400) Record Definition
Field Name
Format
START_​DT
A10
CI_​BSEG
END_​DT
A10
CI_​BSEG
BSEG_​STAT_​FLG
A2
CI_​BSEG
BSEG_​AMT
S13.2
CI_​BSEG_​CALC_​LN
Top of Page
Bill Calculation Header (0500) Record Definition
Field Name
Format
START_​DT
A10
CI_​BSEG_​CALC
END_​DT
A10
CI_​BSEG_​CALC
RS_​CD
A8
CI_​BSEG_​CALC
CALC_​AMT
S13.2
CI_​BSEG_​CALC
DESCR_​ON_​BILL
A254
CI_​BSEG_​CALC
Top of Page
Bill Calculation Line (0600) Record Definition
Field Name
Format
APP_​IN_​SUMM_​SW
A1
CI_​BSEG_​CALC_​LN
CALC_​AMT
S13.2
CI_​BSEG_​CALC_​LN
EXEMPT_​AMT
S13.2
CI_​BSEG_​CALC_​LN
UOM_​CD
A30
CI_​BSEG_​CALC_​LN
TOU_​CD
A30
CI_​BSEG_​CALC_​LN
SQI_​CD
A30
CI_​BSEG_​CALC_​LN
BILL_​SQ
S12.6
CI_​BSEG_​CALC_​LN
DESCR_​ON_​BILL
A254
CI_​BSEG_​CALC_​LN
Top of Page
End of Bill Calculation Header (0700) Record Definition
Field Name
Format
Dummy field
Top of Page
Bill Segment Read (0800) Record Definition
The Bill Segment Read (0800) Record is not applicable for Customer to Meter (C2M). A quote detail bill segment doesn’t have read details.
Top of Page
Bill Segment SQ (0900) Record Definition
Field Name
Format
UOM_​CD
A30
CI_​BSEG_​SQ
TOU_​CD
A30
CI_​BSEG_​SQ
SQI_​CD
A30
CI_​BSEG_​SQ
SQ_​DEC_​POS
N1
CI_​BSEG_​SQ
BILL_​SQ
S12.6
CI_​BSEG_​SQ
Top of Page
End of Bill Segment (1000) Record Definition
Field Name
Format
Dummy field
Top of Page
End of Quote Detail (1100) Record Definition
Field Name
Format
Dummy field
Top of Page
End of Quote (9999) Record Definition
Field Name
Format
Dummy field
Top of Page
Address Sub-Record Definition
The address that appears in both the quote record (0100) and the quote detail record (0200) is composed of the following:
Field Name
Format
Description
COUNTRY
A3
ADDRESS1
A64
Refer to Completing A Quote Creates Quote Routings for a description of conditions when this field will contain a fax number or an Email address rather than the first line of a postal address (this only occurs for a bill record (0100)).
ADDRESS2
A64
ADDRESS3
A64
ADDRESS4
A64
CITY
A30
NUM1
A6
NUM2
A4
HOUSE_​TYPE
A2
COUNTY
A30
STATE
A6
POSTAL
A12
GEO_​CODE
A11
IN_​CITY_​LIMIT
A1
Top of Page
